Originally posted by: BrownTown
machines ftw
machines FTL
Originally posted by: bignateyk
Alot of people think that by using machines they dont need to know proper form. In my experience, it is actually easier to lift using bad form on machines than it is to lift using bad form on free weights, and you can really injure yourself using machines by using too much weight and using bad form.
If you are going the machine route, at least use cable machines or hammer strength machines. Nautalus and Hoist machines are terrible.
Wait, why would machines be worse than free weights, that seems kinda counterintuitive to me. I mean first off with the machines you are pretty well forced to only do one type of thing since they only move in one direction. Secondly, they all seem to have alot better saftey since if you can't lift the weight there is usuall some bar or other device to keep the weight from falling on you if you let go.
No, quite the opposite, with the machines it seems like you are locked into a certain form and don't have to worry as much about proper form as with free weights.
They're worse because you can push against bearings and put bad torques on your joints. They also don't develop stabilizer muscles or anything like that. I want you to go build up your legs on a squat machine, and then try to do real squats at the same weight. You'll fall on your ass.
Safety is not a problem with free weights except for BB flat, incline, and decline presses. Even then you just get a spotter or use DBs if you're alone. The couple times I've gotten stuck on BB incline I just lowered it to the floor, did a clean and jerk to get it back up to chest level, and put it back on the pegs.
OP also check out http://www.bodybuilding.com/fun/exercises.htm.
Originally posted by: IcebergSlim
why not pay for a few sessions with a professional trainer. Probably worth it in the long run.
