For all you thread crappers, why not just refrain from posting your comments? Sure, a 4" woofer may not be enough for one person - and 10 watts might not be enough power handling for another individual. However, this is the "hot deals" section and $22.88 does qualify as a hot deal. If you're looking to spend $1,500 on Mirage speakers, then you'll have to look beyond this forum to find what you need to suite you.
Finally, these are surround speakers. If you have an adequate subwoofer, the 4" woofer will be more than enough. Set the frequency response to cut-over at 100 Hz and you'll be good to go. 10 watts per channel is nothing to sneeze at. Most people never use more than the first 2 or 3 watts of power anyways, so this could be a great deal for some people.
