PIO/DMA Problem with Plextor 16/10/40A
Diomedes01
10
Hi all,
I recently upgraded my box to a 1.2Ghz Athlon running on an Asus A7M266 w/ 256 MB of Crucial PC2100. I installed a Plextor 16/10/40A as the only drive (set as master) on the secondary IDE controller. The problem is that the BIOS will not set the drive to DMA-2 mode. If set to auto-detect, it sets PIO mode to 4 and disables DMA. In Win2k, if I check the IDE controller settings, it is set to "DMA if available", but the current mode is always listed as PIO. Does anyone have any suggestions?
Thanks,
Will
Jun 6, 2001
119
that may be a bios issue...have you flashed to the latest version? if not try that...
other than that, i dunno...if manually setting the udma and pio the way you want it dowsn't work, you may be stuck with what autodetect gives you :frown:
MaxImuM
aUt0eXebat
Banned
Oct 9, 2000
2,353
try installing win2k pro, i have the same drive and win2k pro, but before sp2, it still worked fine. it must be the BIOS, but id try sp2 if you dont already have it
h0vic
735
After changing the IDE controller settings to "DMA if available", did you restart your computer? I have the 1210A and after restarting, it shows the current mode as DMA.
GregANDTCH
1,370
Hey,
I think there's a "jumper hack"
for this drive that forces your computer to
see it in "DMA mode".
Somewhere in this thread:
Thread
CivilRightsLawyer
345
that is right..there is a jumper hack..
just jumper the two pins on the far LEFT side (if you are holding the back of the plextor drive and facing you)..
more info at
www.cdrinfo.com
i havent tried yet...
