pins for voltage control on socket A
Abzstrak
ok, so I can't seem to find this. I know I should be able to put a small piece of wire between two holes in the socket and put the chip in to bump the voltage, but I can only find instructions for TBirds, not Athlon XP/MP I think those both should be the same (XP/MP), but if not I need to know for MP's.
and no, the motherboard has no voltage/fsb settings at all.... Its a tiger MPX.... actually if anyone knows of a hacked bios for it that allows some manipulation that would be cool too ;-)
TIA
That guide should work. I used it when I wire-modded my MPs on my K7D-L. If you are not using real MPs, you will still have to L5 mod the chips as afaik you cannot enable SMP via wire-modding
