Pin modding mobile processors
Liver
How do people figure this out? I mean how does a person figure out that a simple pin mod will work?
Clearly they are smarter than me, but how does it happen?
I am astonished and in awe.
For the pin mod in notebook computers (I'm assuming your referring to for the P-M's and celeron M's) the logic is this. We knew there is a chipset that supports both 400 fsb and 533 fsb, and processors that run at either of these speeds. The processor has to tell the motherboard what kind of variant it is (400 or 533) so it communicates this through a couple pins bsel1 and bsel0 I believe. To figure out what pins communicated the speed you could look to intels white sheets which defines what every pin is for, and from there you just have to figure out how to make the 400 fsb variant look like a 533 fsb variant to the mobo, in this case by grounding bsel1 I think. I did not figure this out originally it was some1 else, however I did figure out the same kind of mod for my P4 630 in a dell 8400 which allows me to run it at 4 ghz.
Intel White Papers are your friend.
Zap's 2002 FSB pin mod.
The white papers will also tell you what pins control "detected" voltage and what all possible values are. Athlon XP are more fun (at least ones not hard locked) because you can change multiplier.
