pin layout on audigy cards??
beverage
so...i finally took the big step and bought the case i'd been drooling over for months now...the antec sonata. so far I love it.
Only one small problem, the connections for the front sound and firewire are all made to connect to headers on the mobo/soundcard. well turns out there is no pin layout diagram for my sound card...the soundblaster audigy...to be found on the internet (at least not that i've found after about 20+ mins of searching.
I was able to find a rough guide for the firewire connections and will be able to test it out using my roommate's ipod in a day or so. but i really have no need for it, but i'd LOVE to have the front audio ports working. The pins on the card are made to be able to connect to on of the audigy drive thingys ... but the correct pins for speakers and mic have to be in there somewhere, so my question...does anyone know which pins are which?
Can't be done without a creative Live! drive. Sorry. Give creative more money if you want headphone connectors on the front of your case. Unfortunately you'll also have the rest of the horrible baubles that anoint the front of live drives...
Pick up an Audigy Drive from creative.
Note: the live drive is for the Live series. The Audigy drive is for the audigy series.
