PIII 600 MHz "Katmai" vs "Coppermine"
Biggs
3,010
Assuming everything else is constant, which is faster for "everyday office applications"?
1) PIII 600 MHz "Katmai" with 512 KB half speed (i.e. 300 MHz) cache
2) PIII 600 MHz "Coppermine" with 256 KB full speed (i.e. 600 MHz) cache
Mar 19, 2003
18,289
I really doubt you'll notice a difference, but if I recall correctly, the Coppermines were faster overall.
stevty2889
7,036
8
The coppermine was a tiny bit faster, and I believe uses a 133mhz FSB(could be some that are 100mhz fsb, dont' remember for sure), but for every day office applications...very unlikely to notice much of a differance at all...
0roo0roo
64,795
84
yea i think the cumines had 133mhz bus. different minimal.. maybe the cumine runs cooler.
Cerb
17,484
33
86
Coppermine will be a bit faster, regardless of FSB speed. The Coppermine CPUs were when they again went to on-die L2 cache.
Amaroque
2,178
There are 100 MHz FSB Coppermine's. But a Katami is .25nm, while the Coppermine is .18nm.
The Cumine should run cooler, and a bit faster, given the same FSB, and core clock speed. Also, the Cumine will OC better, if you're into that. :)
Trente
1,750
Actually, Pentium 3 chips who were of model B, operated at 133MHz FSB; Those who also had an E added, were Coppermines. So, there was a P3 600 'B', which was a Katmai operating at 133MHz, and there was a 600 'E' & 'EB' - the former is a Coppermine running at 100MHz and the latter is a Coppermine running at 133MHz. Conclusion: a Pentium 3 600MHz could only be one of those three: B/E/EB
wisdomtooth
1,155
CuMines are faster and cooler, which makes them far more overclockable than Katmais.
BTW, a CuMine P3-600E can be run as a P3-800EB.
HTH.
