I'm in the process of overclocking my 965BE, but being new to AMD, I'm not sure of what voltages/temps are safe.
As it stands right now (with P95 running small fft's), my core voltage is 1.44 & temps on all 4 cores is 52c. Currently running @ 3.825Ghz.
Is that acceptable?
Is the small fft's the test to use w/AMD processors for stability check or should I use "blend"?
Thanks.
Is that acceptable?
Thanks.
