Hope this question isn't too silly;
I just replaced fan on my old PII400 CPU (in SECC1 cartridge). While checking the fan functionality, I noticed it's blowing into the heatsink (I always somehow thought it's opposite). It seems to be working fine, since cold air rushes through all those grills there and blows out on the sides; it just surprised me... Btw, this was the only way how to attach this 50mm fan (which I removed from other SECC1 heatsink of a slightly different model, since mine was more massive and I wanted to keep it). After plugging the replaced fan in other 3 pin socket just to check out the direction, it was the same; blowing inwards.
Is there any rule which direction CPU fans should blow? Maybe depends on type of used heatsink?
Can someone explain; thx?
