Picture quality is worse with KVM
S0Y73NTGR33N
420
I just hooked up my two computers with an AirLink 101 2 port KVM switch. Now it's like I can see my picture refreshing.. it's not horrible but I wonder if there's a way to make it stop
Is this common with KVM switches? It does it for both of my computers
It's like there's waves going up the screen.
-green
Tiamat
14,068
generally the more devices you go through between the computer and your eyes, the more drop in quality. I dont know why your screen seems to be shaking however. When I tried using a cheap KVM, i got ghosting - in its true sense, that is, i got double images slightly offset from each other, one really dim, but very noticeable.
Vegito
8,329
i had this problem before..
it was with cheap cables off the kvm..
kvm adds distance between your pc and monitor.. you can try to get a shorter cable and see if it helps.. or try different brand
S0Y73NTGR33N
420
seems like theres nothing I can do... oh wellz...
it's barely noticeable but we'll see I'm gonna go play some farcry.. if I notice it then I'm gonna return it.
