- Aug 9, 2000
- 18,378
- 2
- 0
1. An elevator cable breaks when a 735 kg elevator is 22.5 m above the top of a huge spring (k = 8.00 x10^4 N/m) at the bottom of the shaft. Calculate the amount the spring compresses. (Note that here work is done by both the spring and gravity.)
I keep getting .09m. If work is done by the spring, how do you calculate its work?
2.A 5.0 kg block is pushed 8.0 m up a rough 38° inclined plane by a horizontal force of 65 N. If the initial speed of the block is 1.7 m/s up the plane and a constant kinetic friction force of 28 opposes the motion, calculate the the final kinetic energy of the block.
I got 3.38, but my friends tell me it is wrong.
3. What should be the spring constant k of a spring designed to bring a 1420 kg car to rest from a speed of 111 km/h so that the occupants undergo a maximum acceleration of 5.0 g (1 g = 9.8)?
4. A 1200 kg car rolling on a horizontal surface has speed v = 60 km/h when it strikes a horizontal coiled spring and is brought to rest in a distance of 3 m. What is the spring constant of the spring?
I keep getting 7173 and 1420
