Physics Help
Xylitol
6,617
I dont remember how to solve these problems
But can smeone help me
A book sliding across alon ga horizontal table has a constant frictional force of 4 N acting on it. If it has a mass of 1 kg and an initial speed of 8 m/s, how long will it tkae to come to rest?
I know for a lot of you guys thsi is easy, so can you tell me how to do it?
tyler811
5,385
:confused:
Sorry you lost me at "alon ga horizontal table has a constant frictional force of 4 N"
PurdueRy
13,837
4
<-Official HW helper of ATOT
This should be right:
F=ma
4 = (1kg)a
a = 4m/s^2
vf = V0 + at
0 = 8m/s + (-4m/s^2)t
t = 2 sec
For distance it will slide:
Vf^2 = V0^2 + 2ax
0 = 64 + 2(-4)x
8x = 64
x = 8 m
hypn0tik
5,866
The best way to start is by drawing a free body diagram. From there you analyze the forces you have and use equations relating the stuff you know.
Also, make sure you properly define the co-ordinate system you choose and be consistent throughout. That'll take care of the signs for you.
Fenixgoon
33,272
12,836
F = MA
4 N = 1kg x A
A = 4 m/s^2, v = v0 - at
0 = 8 - 4t
t=2
mackle
257
bump for a physics question....I think I can help if I was in my Physics class but after I graduated.....I gave everything back to my prof....you should go ask him...:D J/K
PurdueRy
13,837
4
It's been answered...twice...
mackle
257
and which is the right answer....:confused:??
PurdueRy
13,837
4
They are both the same?? :confused:
kukyfrope
344
You can find the answer to this problem by having a friend drive at 8m/s down the road and you jump out the window. Use a tape measure to measure the length of blood splatters.
Xylitol
6,617
F=ma
4 = (1kg)a
a = 4m/s^2
vf = V0 + at
t = 2 sec
Vf^2 = V0^2 + 2ax
0 = 64 + 2(-4)x
8x = 64
x = 8 m
Holy crap man you're like 10x smarter than me :D
I didnt even know how to get the Fpush
I guess 8 m/s push = 8 [N]?
