Physics Help
Heisenberg
10,621
Break the tension into x and y components using the angle. The x and y forces each have to then add up to zero.
StevenYoo
8,628
methinks u need the horizontal component of the tension in Cable A.
horizontal component = 750N * cos30
is that the tension in Cable B?
Heisenberg
10,621
Originally posted by: jessicak
I thought it was 750*tan30
but i may be wrong
That sounds right. The vertical component of cable A has to be 750N to balance the mass since it's exactly vertical. Then the horizontal component would be 750*tan 30. I think anyway.
tikwanleap
but i may be wrong
Yep Heisenberg is correct!
tan 30 = opposite / adjacent = horizontal component / vertical component = x / y
solve for the horizontal component:
x = y * tan 30
we know y = 750N to balance out the vertical weight.
so x = 750N * tan 30
