alphatarget1
consider the vector A=5i-3j Find:
a unit vector n1, parallel to( and pointing in the same diresction as) A. is your answer unique?
I don't get it, i looked up the answer and n1 = .86i-.51j and the answer is unique. how can it be unique?all i need is the same slope and the same direction and everything should be correct...
