James3shin
So I'm helping my friend out with some physics 1, specifically momentum. The problem reads:
A radioactive nucleus, initially at rest, decays by emitting an electron and neutrino perpendicular to eachother. The linear momentum or the electron is 1.2x10-22 kgm/s and that of the neutrino is 6.4x10-23 kgm/s. Find the direction and magnitude of the linear momentum of the nucleus as it recoils.
I think I found the magnitube of the momentum by using the pythagorean theorem of the momentums and obtained:
1.36 x 10^-22 Kg m/s
For the direction portion, I tried taking the tangent of the two momentums and then taking the Tan inverse to get the degrees and I got:
1.875 degrees of deflection.
Correct or Incorrect?
