PHPMyAdmin Problem....*SOLVED*
Al Neri
UPDATE!
It turns it out Magic Quotes somehow got enabled - Didnt even know wtf that was !
Problem solved!
I have PHP 5 and PHPMyAdmin, Server version: 5.0.51a-community, Protocol version: 10 installed on my server space.
When I input:
Select * from Database where FirstName='Mike'
and
Select * from Database where FirstName="Mike"
I get back (this is an example for single quotes - when i input double quotes the example comes back with double quotes):
Error
There seems to be an error in your SQL query. The MySQL server error output below, if there is any, may also help you in diagnosing the problem
ERROR: Unknown Punctuation String @ 37
STR: =
SQL: Select * from EmpList where FirstName=\'Mike\'
SQL query: Documentation
MySQL said: Documentation
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '\'Mike\'' at line 1
If I click go back it shows the Query as
Select * from Database where FirstName=\'Mike\'
With the slashes added back in.
Is this a bug - or is there a workaround?
Thanks,
Don R.
