Photoshoppers- help!
CarpeDeo
Hey guys . . .
I'm trying to edit this picture i took with my digital camera . . . i need to remove all the blue from the picture- but there's like 100 gradients of blue- and I only know how to remove one specific color at a time using Paint.
How do i remove all the gradients of blue?
Thx!
you could do Select -> Color Range -> and then click on a blue area, then set the fuzziness to a high number. click ok and then you can delete it. also you could key the color out, i think.
This would work. It could be difficult if there isn't a clear distinction between blue and the other colors.
I would just turn off the blue channel. Boom done.
