- Nov 18, 2005
- 646
- 0
- 0
So I have an AMD X2 3800+ @stock and when I use photoshop... It never utilizes both cores
. It only uses one, anyone know how to fix this?
Thanks
Thanks
Originally posted by: Nohr
Did you try setting the affinity to both cores in task manager?
Originally posted by: MrWizzard
1.Which photochop version are you using?
2. When you start photoshop it does it detect the 2 CPUs?
3. Did you upgrade your CPU after you installed your OS from single to multi core?
4. Did you upgrade your CPU after you installed Photochop?
ALL these are reasons it might not be using both cores...
Originally posted by: teatime0315
In the task manager it only goes up to 50 percent for cpu usage and never past that.
If it utilized both then it'd be running at 100%![]()
You have the AMD dual-core patch for windows?
Why would it use 100% of your CPU? Ur CPU is more than fast enough to run photoshop nicely. In task manager under performance, is the 'CPU usage' graphic showing two columns or just one?
ahh... I see thanks ... I thought PS used Both cores at all times... guess not. Thanks for clarifying things ElDonAntonio and KaOTiK
