Photoshop help...
The Wildcard
2,743
Okay i keep forgetting how to do this and i am too lazy to figure it out so i thought i try here. How do i produce a very thin black horizontal banding? I know it involves the pattern and fill commmand.
loup garou
35,132
No prob. That site helped me out alot when I first started using Photoshop...I can't believe I remembered it! :)
DefRef
4,041
You can avoid the need for making a new document this way:
1. Create a new layer.
2. Use single pixel marquee to make selection.
3. Fill selection with black.
4. Zoom in on this one pixel line and then turn off ALL other layers but this one. (Alt+Click the eye in the Layers pallette) Deselect line.
5. Using the rectangular marquee, select the line and ONE pixel below it. It doesn't have to be very wide and not the whole width.
6. Select Edit>Define Pattern.
7. Clear the layer out. (Ctrl+A, Del)
8. Zoom back out to whole picture and then go Edit>Fill... and use Pattern for the contents.
This will fill the whole image without regard to image width.
