I am using the Linksys Phoneline 10M Network cards and as soon as I boot my older
system and the two phoneline network cards try to communicate my KT7A-Raid
system slows to a crawl. I can access the my KT7A-Raid system from my old Tyan S1598-C2 K6-III 400 no problem... move files, access all shared drives, and Sisoft Sandra says the network is working just fine from the Tyan side of things. All the time this is happening the KT7A-Raid system is running like a 286.
My Abit system is as follows:
KT7A-Raid
1 Gig T'bird unlocked running rock solid stable at 9 X 133 = 1.2 Gig.
256mb (2 X 128) PC133 SpecTek Cas 3
3dfx V5 5500 AGP
SB Live! Value
Siiq PCI / usb controller card (couldn't get VIA usb to work)
30 Gig IBM GXP75 Deskstar (master on ide1)
Samsung 48X cdrom (master on ide2)
USRobotics 56K Ext. on Comm 1
The Live! Value is in PCI slot #2,
The Linksys network card is in PCI slot #5 with onboard Raid chip disabled to give it it's own irq,
The Siiq pci/usb controller card is in PCI slot #6.
Everything has it's own irq except the Live! Value card with shares with acpi... doesn't seem to be a big deal as I am not suffering from any dreaded pops and crackles.
Linksys tech support had me on the phone for over an hour installing and un-installing then re-installing drivers and finally concluded that my home has bad phonelines... so after hanging up I moved the two systems side by side and used their phoneline to connect the two systems... same problem... Tyan system works fine, Abit system crawls.
Linksys tech support have not yet returned my call or email after finding this new fact out but when I did have him on the phone originally I questioned him about client/server settings he blew me off because it is a "peer to peer setup and it doesn't matter which is client or server, you don't have to worry about those settings". I don't know much about networks so I had to go by what he said but I'm really starting to wonder now.
If anyone can help I'd really appreciate it.
TIA,
Robin
KT7A-Raid
3dfx V5 5500 AGP
SB Live! Value
TIA,
Robin
