Phone scratch is driving me crazy.
EpicAbcdude
The other night I discovered my month-old Samsung Galaxy S7 got it's first scratch. From what I can tell it's an oleophobic scratch, since it only shows up in the right angle of light, and running my finger across it I feel nothing, but gosh does it bother the heck out of me. Picture of it in direct light: http://i.imgur.com/Iyjqpmh.png
I'm pretty sure it all boils down to my OCD, i'll seriously stop using it to point it at light and say "Mhm yep, still there". I know there's no real way to fix it, but from what I hear a good tempered glass screen protector can make it far less visible. Should I just try to let it go and enjoy it for what it is or start shopping for a protector?
MarkizSchnitzel
466
So, that huge ugly sarcophagus you got on it did not help? Looks like it has raised lip :/
I just read that GG5 on the Note7 is very scratch prone, far more than GG4, does S7 also use the new one?
Reactions: shortylickens
EpicAbcdude
I... don't know? I mean I wasnt putting huge trust in my case protecting the front anyway from scratches and JUNK anyway, as long as it can save me a drop or two.
GG literally seems like it's taking a step bacl every iteration. GG3 had below average scratch resistance, GG4 was worse, and now GG5 is somehow even worse? Yeesh.
John Connor
22,757
618
121
I believe an auto parts store might have a small crack repair liquid that might help. What it does is fill into the crack.
I take no responsibility for my suggestion. LOL :D
Edit- You're not suppose to use profanity outside of Off-topic. I would edit your post.
boomerang
18,883
641
If you find a glass screen protector that you like let us know. I tried out several and they all lifted along the long edges as the screen rolls off there. I haven't checked in several months so maybe somebody has been able to manufacture one with that small curvature integrated into it. I think that would really complicate application to the point of near impossibility so they may never even be made.
You'll dislike the lifting more than the scratch.
isekii
28,578
That's not the edge model. There isn't a tempered glass for the standard s7? I thought it was flat
boomerang
18,883
641
Not along the long edges. It rolls off slightly. The problem is that a glass protector that will not lift at those edges is so narrow that people complain about dragging their fingers over the edges of the protector.
isekii
28,578
Ah... someone make a curved tempered they'll make some good money.
ericlp
6,137
225
First of all you need a new case protector... try spigen...
I've had my s6 for about a year, I try not to put my keys and phone in same pocket, but it happens. So far no scratches on my phone at all, I don't have any protection on other then a case protector (noted above) that does have a slightly higher lip around the front and lip around where the camera is.
Anyway, you could try toothpaste, or that wax for the car headlights that make them new again, stuff is suppose to fill in the cracks then you buff it out. I think you are screwed tho, for not noticing it. It's like finding that one dead pixel on a DLP projector, when watching movies once you find one, you will always kinda look for it!
Let us know if you find anything that works!
WelshBloke
32,683
10,852
No offence to you two but don't do any of the above!
You could try reapplying the coating if it's just that that's damaged.
https://www.ifixit.com/Guide/How+to+apply+anti-fingerprint+oleophobic+coating/9682
Anubis
78,712
427
tbqhwy.com
an oleophobic scratch has very little to do with the glass underneath it, its a coating on top of the base glass, not all phone manufactures use the same coatings, they are similar in function but nearly all different in some way, and some are better then others. its not a feature of the base glass
JeffMD
2,026
19
A polyurethane based skin will hide it well, and give great scratch protection. Try searching for a skinomi skin on ebay, it should come up pretty cheap.
