I've only had the phone for about a month now, and there's already a ton of dust stuck under the inner display of the phone. Has anyone else had this problem? It's quite annoying.
yes
well not me, but my co-worker just got this phone also and there is a bunch of specks under the display screen. You can clearly see them when it goes black.
Mine has the problem too, just go to www.cnn.cn and get a replacement screen cover, they are like $3. Just take the other one off and put a new, clean one, on.
