phone battery question
narutofan36
2,823
i just got an lg chocolate. the dealer told me to keep charging it for 8-10 hours. However, its done charging after 2-3 hours. is it safe to use it now?
thanks
Mday
18,647
The battery is most likely lithium ion, so yes it is safe to use. But the battery may not be FULLY charged though (topped off that is), and may not yield the longest battery life it can yet. Usually when the indicator hits "charged" on the charger, the battery won't be topped off for another hour (depending on the rating of the charger).
