Philips A3.600 5.1 Speaker System
Lonyo
21,938
link to speakers
Philips A3.600 5.1 Speaker System Surround Sound Flat Panel IR Remote Control
[/quote]
Bring the Hi-Fi quality of your home theater entertainment system to your PC!
The MMS306/A3.600 delivers all the performance you would expect from a high-quality sound system with an aesthetic quality usually reserved for your home audio system. Style and performance are perfectly matched with the high power 50-watt subwoofer incorporating patented wOOx bass driver technology and new Soft Flat Panel speakers exclusively designed by Philips.
The MMS306/A3.600 also incorporates Digital Signal Processing (DSP) to turn even ordinary stereo sound into a 5.1 channel surround experience. 6 distinct channels make gaming more immersive and give movies new depth and impact.
Place the speakers anywhere you want and still have all the control at your fingertips with the easy-to-use wireless remote control. And, the MMS306/A3.600 enables you to connect up to three audio sources at the same time -- connect your PC, MP3 Player, CD Player or DVD player and turn your PC speaker system into a complete home entertainment center.
FEATURES
Active 100 watts (RMS) Hi-Fi Multi-channel PC Speaker System
High power for the most intense game effects or music with concert hall realism. Bring the Hi-Fi quality sound of your home theater entertainment system to your PC.
wOOx Bass Driver Technology New!
Philips' patented bass driver design provides rich deep bass from a deceptively small enclosure. Composed of a unique dual suspension design, wOOx bass technology delivers more dynamic bass and sound effects for gamers and music lovers alike.
Soft Flat Panel Satellite Speakers New!
All the performance you would expect from a high-quality sound system designed with an aesthetic quality usually reserved for your home audio system. Style and performance are perfectly matched!
Wireless Remote Control
Place the speakers anywhere you want and still have all the control at your fingertips. With the easy-to-use wireless remote control you can adjust the volume, bass or treble, switch from one audio source to another and control equalizer effects at the touch of a button.
Digital Sound Control
Choose from the three pre-set keys: pop, classic or rock for optimal sound reproduction.
Input Selector
Connect up to three audio sources at the same time directly to the speaker system. Three keys on the remote control are provided to make your audio device selection: a 5.1-channel input for your sound card and two stereo inputs for other audio devices.
Easy Placement
Philips provides a variety options for positioning the satellite speakers according to personal preference: horizontal, vertical, or mount them directly on the wall.
Multi-channel Processing New!
Connect any stereo source, and the MMS306/A3.600 will process the sound and spread it over all the satellite speakers for a rich surround effect. The settings movie, stereo and concert are available.
Magnetically Shielded
Prevents harmful distortion to TV/Monitor.
[/quote]
I currently have an 80w 2.1 setup.
And a SB Audigy original.
Woodchuck2000
1,632
It may be worth upgrading, depending on what your 2.1 setup is...
I'd much rather have a good 2 Channel setup than that philips system
Goosemaster
48,775
Defintely.
I used to have a nice set of Klipsch Promedias and now I have my PC feeding a reciever.
I am only using 2 fronts but it sounds Waaaay better than 4 Promedias
