- Jan 22, 2012
- 366
- 0
- 0
Try changing processor voltage back to Auto.
2) 965 BE doesn't like high temps, you want to keep it under 55C, ideally.
it's a BEC3, but it stays under 51C _at max_. I'm going to get a 212 or a sunbeam 120mm core contact (easier to put on the motherboard since it has the AMD socket 'clamp' already, same if not better performance than the 212) and put a good 120mm fan on it. Should lower the temps a bit from the hyper tx3.
