Phase Change Cooling, Somebody knows something?
ErLeon
Hello,
I'm insterested at build a Phase change cooling system, and i need some information about it. Where can i get information? Anybody knows a site where obtain any information?
Thanks
Leon.
cdrakejr
354
If you do a search for "phase change cooling" on null you will get about 60 hits, most are not related to what you want to do. But I found one in the first ten listed that is exactly what you are looking for:null
You can check out the rest for any more that might apply.
Good luck.:)
Edit: First time trying to use the new "buttons", the two links do work but don't show the URL? :(
