Phanteks announced their power combo peripheral
http://www.phanteks.com/PH-PWCOB.html
From the site:
Phanteks patented Power Combo is design to maximize your power output by allowing you to connect two power supplies. Higher end power supply can cost a fortune, but the Power Combo is cost efficient and provides maximum power and efficiency. With the ability to combine two power supplies, the Power Combo can give you a higher maximum power output than all the power supplies in the market while still maintaining stability and performance. A true plug and play, the Power Combo requires no cutting and splicing of the wires.
Features:
Safe and Secure
Redundant power supply architecture concept, this prevents the system from shutting down when one power supply fails. This ensures that all your vital information and data will not be interrupted or lost.
Power Efficient
The power combo can acquire higher power efficiency through load sharing of 2 PSU's. 2 PSU's will operate under more efficient load compared to a single PSU that would be under full load.
From the site:
Features:
Safe and Secure
Power Efficient
