Despite the relatively closed off panels, the trio of 140mm fans work well to keep temperatures in check. The exhaust fan is usually the most important one as far as CPU cooling goes, and it does a decent job of removing hot air from this important area, keeping our CPU at a delta T of 50°C.
The graphics card, too, is well looked after by the dual intakes, especially as there's uninterrupted airflow from front to back. The delta T result of 43°C is the lowest we've seen from a case using the new test gear. Admittedly, the differences aren't massive, but it does indicate that the Enthoo EVOLV ATX is more than capable of cooling a single GPU system, and we'd wager that with appropriate spacing between cards it wouldn't do too bad with SLI or CrossFire set-ups either.
