Phanteks enthoo pro front panel headers help.
Indiankash
21
Guys i just upgraded my motherboard from z97-ar to a z170-ar mother board. i have a enthoo pro case and i am having trouble turning it on. i don't remember how i wired it earlier but i don't know where to put the second pwr-sw cable.(the first picture). when i plug everything in and turn on the power supply the led where it says pwr-sw turns on, it green.(second picture) you can't see the led in the picture but does turn on. also the reset is directly behind the pwr-sw. any help would be great. thanks in advance.
https://gyazo.com/fec5cf1e074c56d193fd3602a5ab214e
https://gyazo.com/cacec22cf3201c6e9c4275d848c54745
Ketchup
14,559
248
Hmm. The manual only mentions one, that I can see. First thing I would try is reversing the one that's there now. If that doesn't work, try swapping with the other both, also trying directions.
Indiankash
21
tried all direction, none of them work. also i cannot figure out why the motherboard led lights up but it doesn't turn on when i press that button.
Ketchup
14,559
248
Might not be that button. Might be a loose or missing screw on mounting the board, a missing power connection to the board or video card, a fan not connected to the cpu fan connection on the board, etc.
Great looking case btw.
DAPUNISHER
32,481
33,546
The power switch is usually on the other side of the Q connector with the reset and hdd. You can also short the pins on the board to see if it powers on. If it powers on, you could have a faulty power switch or the wire could be broken loose from the switch. Or you are not wiring the Q right.
I have used that case for builds, and the first time I used it for my son's system, I was impressed with the build quality and features for a $70-$80 full tower. Other than the plastic front it is solid and heavy, and I really like the included fans, grommets, fan hub, psu cover, included hardware and its organization, and the clean look. Tempted to stock up on them...
