Phanteks Enthoo Evolv Shift, will this AIO cooler fit?
QueBert
22,992
1,185
I'm leaning towards this case, and I'm looking at the NZXT Kraken X62, teh Googles I can't find a yes or no as to if it will fit. If it matters this will have a Asus ROG Strix x370-i Gaming ITX.
QueBert
22,992
1,185
thanks for the reply DOH! Typo, I meant X42. I also forgot to mention on pcpartpicker it told me it's not compatible, but it also said it was unable to verify. I don't see any reason it won't fit, but I've built so many computers in the past where I just assumed a part would fit, and it wound up bitting me in the butt lol. So I thought I better make sure before I spend money.
Campy
785
171
https://pcpartpicker.com/b/X6Bbt6
"Hey,
so I have decided to change my old build and buy new Phanteks Shift case and also use a NZXT Kraken cooler...
As you can see, there was an issue to fit rad from kraken. Well probably the only way was to fit it under PSU and this is a result (more in pic). It interfere with on/off button on PSU so if you want to go same way I recommend to choose different one. Definitely SFX and not SFXL - full modular help. Anyway PSU is quite stable there for now.
*You can't fit rad on side (vertically) - side is max 140 and K42 is more (175 x 143 x 30)."
Guess it's still a no then, he ziptied his PSU lol
