nerp
Ordered this case to complete my build. I'm getting the white S (silent) version. Reviews are all very positive but I'm wondering about airflow. One reason I'm upgrading my case is my current case, a Lian-Li PC-A05B gets a bit hot when I'm gaming. It's a great case but the inverted mobo and reverse airflow layout makes heat pool at the top of the case since the video card is pointing up to the top and there's not a lot of space there. Plus, it's an older design so nothing is removable, the drive cages are empty but blocking air and I'm not going to start drilling and cutting holes in the case.
So the Phanteks Eclipse 400p will give me a nice clear interior with no obstructions, plus it has a basement for the PSU and stuff, not to mention it looks good. But reviewers have mentioned some airflow concerns though nothing severe. I can't seem to find a concrete answer about what exact fans come with the case.
I feel like I will need to address airflow somewhat. I am not water cooling and I don't think I plan to. My CPU is not overclocked, the front and rear rad mounting areas aren't ideal (there are other better cases for watercooling) and I don't feel like putting a block on the GPU.
That said, I'm thinking of yanking the included fans and replacing them with noctuas. Would 2x140mm mounted on the front and one 120mm on the back be sufficient? I could also use one of the two 140mm mounts up top for exhaust. Or would the single rear exhaust be enough?
My gpu is an EVGA GTX1070 SC, so it blows heat when the fans are running while gaming into the case. I'm using the stock intel cooler so that too blows air all around. I suppose I could upgrade the CPU cooler with a tower cooler and a fan lined up with the exhaust fan to force air out from the CPU that way. But I'd like to stick with the stock cooler if I can.
I'm interested in hearing from other owners about what they're doing for fans and cooling. I believe that I might be overthinking this. And even when my Lian-Li is very hot to the touch I've been gaming for hours, the CPU never gets overly hot, nor does the GPU. But it's warmer than I'd like. What I'm trying to avoid is putting everything into a new case only to find it gets just as hot or even hotter.
In short, are the included fans decent? And is the top exhaust necessary?
I'm also thinking about whether I should run everything via the mobo fan control/pwm or if I should just get silent high airflow noctuas and let the case fan controller run them. I figure if they're quiet and pushing tons of air, why slow them down if I can't hear them, right? But PWM is nice and costs like $1 more per fan.
Thoughts?
(pics to come)
Should we make an owners club/thread? This case is very popular.
Thoughts?
(pics to come)
