- Aug 10, 2002
- 5,847
- 154
- 106
Replumbed my entire house and we chose pex tubing on plumber's recommendation. You guys may remember a thread I made earlier this year where I discovered rotten plumbing when I took out some walls and decided to do it all over. The water enters the house from the street via a copper line and from here various runs of pex take off to go to various bathrooms, kitchens etc...
The water has a bad plastic taste to it. I just don't like it. We have another house on the same municipal water system so its not the city water. The tubing has been in the walls for a few months now, faucets were installed last month and began use. I hope this is something that just needs to leach out of the tubing and the taste will go away.
I haven't been living there full time so the tubing doesn't get "normal" usage, perhaps this is a factor... I hope that if the pipes were used normally, the plastic taste will eventually wash out. Only time will tell.
Don't get me wrong about pex now. We plumbed the supply side of a 2 story house: 2 full bathrooms, 2 kitchens, 2 laundries and outdoor sillcocks in less then 2 days. That's impressive from a labor standpoint when compared to copper. No soldering, no expensive copper, just durable brass fittings where needed. One tool needed: a tubing expander needed to make connections to other fittings, pipes etc... The tubing can make direction changes easily. Fewer joints overall in the tubing run. Freeze resistant, no corrosion or pinhole leaks. Even if the tubing gets kinked, hit it with a torch and the plastic will reset itself back to normal shape!
Anyway, this is for a rental and if my tenants complain, I can only point to the fact that this tubing is rated for residential potable water supply and to get a Brita filter if it bothers them that much. (Btw, I still drank this pex water, I'm not afraid of the quality just the taste). For my own house, I'll still use pex tubing but for stuff like laundries, toilets, sillcocks and bathroom fixtures. The kitchen sink where we will get the majority of our drinking water from will be a hard copper line.
Using Uponor Aquapex which is Pex-A from what I understand. Anyone know if the taste disappears over time?
