okey ive tried searching petcock drain systems on watercooling loops, but to no luck, all i find is those for cars. These drain systems are much too big for a computer watercooling loop and hence im wondering if anyone here knows how to set one up for a loop.
One of my NV-78 lucite top had a micro crack on the inside and it just got bigger. I already contacted DD and they offered to mail me a new one asap. So now i have to drain my entire system. pull that block off, which is a pain because there linked in SLI, and reinstall the loop later when i new block arrives. Nothing leaked, nor would i really be concerned if it did leak, because im using promochill which is non-conductive.
Since im going to be tweeking my water loop now, Last chance til i do my coolant flush 6 months from now again. So if anyone knows the basis of what a petcock drain is, can you please forward me in the right direction to set one up in my rig. My components are as follows in loop order
res -> D5 -> D5 -> NV-78 -> NV-78 -> Storm -> Rad -> Res
All my tubes are 7/16, and i might think about dropping the new DD chipset block in my loop as well.
Anyhow thank you for your time :]
