John Tzimisces
Hello, I had this place recommended to me by a friend for a persistent issue I've had with the computer in question and my previous machine.
In my previous machine, I experienced intermittent freezing and BSODs while either gaming. At first it was associated with when the machine had been off for a while (I'd get a freeze or BSOD or two and then it'd run smoothly for pretty much however long) and then more recently, I'd get a freeze or BSOD every day while gaming, and then while not gaming, and then more than once a day.
I attributed this to a slowly failing power supply, or the memory, so I replaced the mobo, memory, PSU, and CPU. The build went smoothly and everything actually appeared to be going great after I wiped the boot drive and reinstalled windows 10. A little weirdness during the process due to using a USB 3.1 (I think?) port with the install media that was resolved by starting over with a USB 2 port.
However a couple days ago I dipped my feet back into the closest thing I have to graphics intensive gaming, running fallout 4, and the freezes returned albeit after hours of gaming. The second or third one I got in as many days actually forced me to use my USB windows install media to rebuild winload.exe (which was really scary as that hasn't ever happened before).
Freezes have not happened while not gaming with the new build.
I'm also not experiencing any weird artifacts and otherwise things are running smoothly, except for one weird thing where FO4 simply crashed when first running it, and the computer repeatedly informed me that the graphics didn't have permission to interact with the program, or something to that effect.
I'm investigating a couple free options but if you guys have opinions I'd really appreciate it. I haven't made any tweaks to BIOS yet and have no intention to overclock (I don't think the H170 mobo I have is suited to it anyway). I don't allow the computer to sleep, and I use the default balanced power plan otherwise.
I've replaced the surge protector because the old one is well over a decade old, but the issue persists.
Next, I'll be replacing the SATA cables for the SSD and HDD with cables that came with the mobo (I have been working on the assumption that the ones currently in use aren't old, since both of those drives were installed a year ago).
Mobo: MSI H170 gaming M3
Memory: Corsair Vengeance LPX 16GB DDR4-2133
PSU: EVGA 750B2 semi-modular (there are no old power cables in the case, other than a weird connector on the graphics card, which allows two 6 pin connectors to connect to the card)
CPU: Intel i5 6500 3.2 GHz
Case: Corsair vengeance C70
The parts which I retained from the previous machine:
SSD : http://www.newegg.com/Product/Product.aspx?Item=N82E16820148820 (I'm pretty sure)
HDD : http://www.newegg.com/Product/Product.aspx?Item=N82E16822236625 (I'm pretty sure, again)
Graphics: GTX 960 2GB (unsure what manufacturer, I'd have to open up the case again)
and the optical drive.
I really appreciate any and all opinions; until this point I was really proud to have been able to assemble this as my first PC build.
