KAMAZON
Hello, I had this chemistry question that really taking a lot of my time and I can't really ask the teacher for too much help since it's kind of hard to really understand him. I wanted to see if anyone can help me out with this example:
http://www.brazosport.cc.tx.us/~chem/tutor/baleqn.html
Example 2:
Balance the following equation which shows the combustion (or burning) of propane:
C3H8 + O2 => CO2 + H2O
Solution 2:
There are 3 carbons on the left, but only 1 on the right. There are 8 hydrogens on the left, but only 2 on the right. There are 2 oxygens on the left, but 3 on the right.
Of the three atoms, carbon and hydrogen are the best to start with. We should save oxygen for last for two reasons. It appears by itself as the element on the left, and it appears in more than one place on the right.
Starting with carbon, we can put a 3 in front of CO2 on the right side to balance out the carbons. Likewise, we can put a 4 in front of H2O on the right side to balance the hydrogens.
C3H8 + O2 => 3 CO2 + 4 H2O
This gives us a total of 3 carbons on both sides, 8 hydrogens on both sides, 2 oxygens on the left and 10 oxygens on the right. To balance the oxygens, we put a 5 in front of O2 on the left side.
Ok i can see that you have to add 4 Hydrogen, but why does the 4 NOT multiply into the oxygen? Isn't the distribution property supposed to be used on this and if not, why not? Any clarification is greatly appreciated. Thanks.
Example 2:
Solution 2:
