Hello,
Apologies in advance for this long winded post. I would just like to share my frustrations with inadequate case cooling inhibiting general pc performance and the things I would like to do to fix it.
About two years ago, before I became an avid do it yourselfer, I purchased a computer from ABS; a place that seemed the closest thing to actually doing it yourself, as they use no proprietary components and just build a PC using the parts you designate. The case my PC came in was the Silverstone SST-TJ04.
Here's a Link
Notice the glowing reviews all celebrating the aesthetics and fine cooling of the case. It actually only includes 2 120MM fans, a rear exhaust and a front intake.
I noticed something was wrong when I routinely noticed temperatures of 53c idle, and 59c load on my FX-53. "ok,", i thought, "maybe I got a bad chip and it just runs hot." So I replaced with an Athlon 64 3800+, which runs almost as hot: 42c idle, 54c load, even when paired with a Thermaltake Venus 12! As a result, my venice chip which is supposedly easily overclockable, struggles to hit 2.65ghz stably (from 2.4 stock), and 1.54v vcore. Lowering the vcore makes it usntable at anything higher than stock. (yes, I know that is more my chip's fault than the cooling)
That's when I looked into the case further: WHERE ARE THE FVCKING intake holes in the front???? It has an intake fan on the inside of the case that is supposed to blow cool air from the outside into the case. Where is this air supposed to come from? Definitely not the front. Or the sides. The bottom maybe? Seems unlikely, there are a few holes there but not enough to let any significant air pass through.
So that is my first question...what is going on with this case, and what can I do to modify it to make it cooler?
So, I did my best to organize the cables and blow the dust out, etc, but it really hasn't done all that much. That's when I got the bright idea to take the side of the case out and just blow a regular desk fan right into it.
Pics
This works great from a temperature standpoint! 35c idle, 45c load even when overclocked to 2.7ghz, and pretty much stable. I then thought to myself, "hey, I don't really mind the noise, can I leave this permanently?"
Well, that's where I am now. Has anyone tried this? Is dust going to be a problem? (wouldnt it just keep blowing it's way out of the case?) Any other dangers I should think about?
I am curious as to what thoughts anyone has had regarding this case, or if someone has seen my layout has any suggestions as to what else I can do. I mean, it's not the best cable management, but it's not the worst either. I have no idea why it's so hot.
Finally, I would like to start investigating the viability of water cooling. If someone thinks that would help a lot and could be easily implemented into the system, please PM me. I am looking for someone in the Bay Area who could be a consultant on this project and who could help me install it. Pay would be negotiable (around $30-40 an hour is all I could afford), or returned with services in kind, as I am soon to be alaw student at UC Berkeley.
Ok, sorry this was so long, but any thoughts are greatly appreciated. Thanks so much.
Here's a Link
Pics
