Perl help
mmej
Hi
I wonder if anyone can help me here with perl as I'm only good in shell scriptting and i've been asked to do something in perl.
Basically i need to monitos a specific directory permanently. And once the files are delivered I have to generate a log and check if it is a duplicate and then forward it to an output system acording to the file type.
Here's an example:
FILE: MVNO_XXXXXX_MMS_PREPAID_Batch_id_FileSeqNum_YYYYMMDDhhmmss
OUTPUT SYSTEM: FRAUD & MDS
FILE: MVNO_UNB_XXXXXX_BatchID_SwitchId_YYYYMMDDhhmmss
OUTPUT SYSTEM: MDS
I know it's not an easy thing but in sh it would be simpler for me.
thanks anyway
Cogman
10,286
147
If you really, REALLY, wanted to. Perl scripts can pretty much act exactly like a sh script. using back ticks (`) you execute a shell command. For example
my $frank = `cat bob`;
would put whatever is in bob into frank.
I wouldn't recommend doing this for all of your code, but it could be useful to try and get yourself better situated.
If you have specific questions, you'll get a better response. We won't write the script for you but we will answer questions to problems that you have.
mmej
Ok fair enough, i wasn't expecting you to do my job-:)
would you let me know if there's a way of getting the first and the last records of a file, ommiting the header and trailer?
thanks
Charles Kozierok
6,762
I could probably whip up an AWK script for you pretty fast. Just not sure exactly what you need it to do, please clarify?
Fallen Kell
561
Well, if all you need to do is match one of those 2 patterns and check against previous files:
#!/usr/bin/perl
my $watch_dir = "/complete/path/to/watch/directory";
# This comes down to what you mean by duplicate
# This will check against all files it has previously processes
# with this script and will notify if it is a duplicate
my $previous_seen_files = "previous_files_list.txt";
open(PREV_FILES, ">>$previous_seen_files") or die("Could not open file: $previous_seen_files: $!");
opendir(WATCH, "$watch_dir") or die("Could not open directory: $watch_dir: $!");
my %previous_seen_files = load_previous_files($previous_seen_files);
while(my $file = readdir(WATCH)) {
process_file($file, \%previous_seen_files);
# Creates a hash table of files previously seen by your script
sub load_previous_files {
my $filename = shift;
my %ret;
open(IN, "$filename") or die("Could not open file: $filename: $!");
while(<IN>) {
$ret{chomp($_)} = 1;
close(IN);
return(%ret);
sub process_file {
my $file = shift;
chomp($file); #removes any newline character at the end
my $previous_seen_files_ptr = shift;
#Check that I have not seen it before
if (exists($previous_seen_files->{$file}) ) {
#Do something as I have seen this file before
else {
$previous_seen_files->{$file} = 1; # Updates the hash table saying that you have seen the filename
print PREV_FILES "$file\n"; # Appends the filename to the end of the previous_seen_files
if ($file =~ /^MVNO_UNB_.+_BatchID_SwitchId_\d{14}$/) {
#Output to MDS
elsif ($file =~ /^MVNO_.+_MMS_PREPAID_BatchID_FileSeqNum_\d{6}\s\d{8}$/) {
#Output to both MDS and Fraud
else {
#Unknown filename patern
mmej
thanks but in awk i could do it as well...but people here want it in perl...anyway i'm almost done thanks to al you're help
regards
