Over the weekend, I installed an Athlon 1.3GHz, retail kit, (upgrade from Duron 850MHz), a Pioneer 305S (SCSI) DVD-ROM (replacing a Plextor SCSI CD-ROM), and a Quantum 60GB Fireball Plus AS IDE (in addition to existing IBM 20GB and 10GB drives, all 7200RPM). I also removed my one stick of 128MB 100MHz memory, leaving just the 256MB of 133MHz memorhy (Crucial), and set the board jumper to run at 133MHz FSB. Everything worked first time.
Last night I was getting the following peculiar, annoying phenomenon: about every two minutes or so, there would be a light grinding noise, and the system would pause. This would last about a second, at most two. After a few seconds it would repeat, and again a third time. (Possibly a fourth or fifth; I didn't count.) But then it would go away, and I could get back to work for another two minutes or so. The pause in the system wasn't total - the mouse would stop tracking, but I could type with very slow responsiveness - sometimes the characters would be queued and all appear at once after the noise stoped.
I tried inserting a CD-ROM into the Pioneer, but the problem continued even with a perfectly readable CD-ROM in the drive. I had run a full scandisk on the drive on Sunday (many hours - perhaps not a good idea). I have the free IBM S.M.A.R.T monitor utility, and it reports no errors on any of the three hard drives. I also have the VIA hardware monitor, and it reports CPU temperature around 42 C and system temperature around 22 C, both of which seem fine. It also reports a CPU fan speed around 4852, which is lower than my previous (default) trigger RPM of 5000, but with the temperature ok, I'm assuming this fan speed is also ok.
As soon as I get the chance, hopefully tonight, I'll reopen the case and see if I can track down the sound. However, the timing of this problem seems so peculiar that I'm wondering if it isn't tried to some software setting triggering some operation.
For what it's worth, this is an IWILL KK266 system, with Windows ME, a 300W power supply (Antec, if memory serves), a Plextor CD-RW (in addition to the new Pioneer DVD-ROM), an old Connor/Seagate Travan TR-3 tape drive, and a floppy drive.
Any suggestions as to likely culprits, or tactics for chasing this down, will be appreciated.
Many Thanks,
Gary
Many Thanks,
Gary
