I need to hook up this
1 modem split to 2 routers each with its own Lan.
I have a visionnet 202ES modem and have tried hooking it up with a netgear and linksys router. If I bypass my router I have no problems. If I use my router I periodicaly loose the ability to ping out past the router. I still have sync on the modem and can still access the router through html. The main router I have been using is a Linksys BEFSR41. This system is up and running, I am using it now. I just get periodic problems for a few (up to 15 that I have caught) minutes or until the router is unpluged and pluged back in.
any help?????
any help?????
