Greetings,
I just wanted some feedback if possible in regards to a build I just recently did. To make a long story short, I had to place the CDRW on the same IDE channel (primary) as the lone HD (obviously HD is master and CDRW is slave). The drive is a Maxtor 7200 RPM/2Meg 40 GIG drive whereas the CDRW is a LG 52X.. that states it is UDMA-2 capable.
The way the board is built and the case I used I cannot get a second IDE cable attached to the board as I would have to dismantle half the case or remove the board. This was a quick fix just to install windows. Anyhow thus, what exactly am I doing... is this going to overall slow down my system? Will it cause issue while burning CDs? Is it really necessary to have the CDRW on the secondary channel?
thanks
Bobo
thanks
Bobo
