Originally posted by: TygGer
Ok... then is there a difference between the many brands of NICs 10/100? Some go for FAR and some are $$$...
3Com, Intel = Good. Netgear..etc. = no good.
My nForce2 board has some nVidia 10/100, but I'm using the also built-in 3Com 10/100, so I can't comment on if it is any good or not.
"MOST" mobo's these days come with some flavor of a built-in 10/100/1000. 99% of the time it is a good 3Com or something chip you can count on very much. Shouldn't be something to concern yourself with.
my intel dual NIC PCI card beats the crap out of any onboard solution (unless its a server board which usually have high grade network chips). The difference to my old SMC was huge! I am not talking about transfer performance but CPU usage by the NIC, it was over 60% less and that is extremely noticeable. I wouldn't use anything else and I will cry the day this card should break.
Must have been a total crap mobo with the built-in 10/100 you're talking about. Every mobo I've ever bought that had built-in 10/100 has been outstanding. (of course I buy quality mobo's too, not them cheap $79 ones.
