Performance difference Between Duron 1GHz and Tbird 1.2GHz??
A Tbird would score about 10 Fps more than a Duron (Same clock speed)
If you buy a Duron get a Board with the new KT133A
so if a Tbird runs at stock speed your duron (overclocked to ex: 1000MHz, using a 266MHz FBS) would be about the same as a TBird 1GHz
So a Duron 1Ghz would 30Fps slower than a Tbird 1.2GHz
So what would yu think would be more performace getting a 1.2 GHz Tbird on KT133 or getting a KT7A with duron at 1GHz??
Don't worry about it - the speed is fairly minimal. If you're a gamer I'd focus more on the video - the Duron and T-Bird are both basically the same core with difference cache sizes and productions, but they perform very similiar in many situations.
