Per monitor DPI scaling.
Status
Not open for further replies.
Eric1987
748
22
I wish I could scale only my 4k monitor but theres no setting to put ONLY my 4k monitor at 125%. Sucks!
saratoga172
1,564
Supposedly this can be done in windows 8.1. I don't know how effective it is other than reading some reviews. I have been looking for something similar for windows 7 on a work laptop I use. Unfortunately windows 7 doesn't have the ability. It's all or nothing.
It looks like you're referencing a windows 8.1 article. I don't know the exact steps since I'd need to test, but if you right click on the desktop and go to screen resolution then choose the display link you should be able to adjust there.
Eric1987
748
22
It'll adjust both if I change it. I just want my 4k monitor at 125-150% and my 1080p at 100% but I haven't figured out how yet.
Status
