Originally posted by: Assimilator1
Smoke
The bulging capacitors isssue was a result of a massive batch of defective caps being sold to various mbrd manufacturers ,mainly around the 99-02 era IIRC.It was nothing to do with heat ,though of course if they blow then that can output quite a bit of heat
Check out
this site ,makes for interesting reading ,with industrial espionage & all!
My main rig's still a Skt A
,I bought this mbrd nearly 4yrs ago (wow that's the longest I've ever kept a mbrd!:Q) ,I haven't noticed any general trend in increasing temperatures other than when I've upgraded CPUs ,upped the clock or vcore.
Have you re-applied the HS compound to see if this returns the temperatures to their as new temps? ,this seems the most likely answer to me mate
The increase in temperatures when running BOINC is amazing!
That is a lot! ,but don't forget that P4s are known for running hot ,more so the Prescott cores.
My XPM @2.5GHz ,1.68v running DPAD now is running at 39C (ext CPU temp sensor) ,55C (int CPU sensor) with 27C case temp.The CPU fan is temp controlled,& is currently at ~3900 RPM
With DPAD off for about 10mins it runs @ 27/36/48C ,fan @ ~3400RPM.
Of course the varying fan speed narrows the temp difference quite a lot ,which isn't helpful for us
but I thougt it might be useful anyway.
Oh & inccidently the CPU runs at about the same temp whether running DPAD or BOINC ,it does run hotter with P95 though ,by about 2-3C.
Btw you owe me a gold star
(I see now someone else suggested the HS compound idea too)
Is that 4-6C drop comparable to 'as new' temps?
Something I do agree about though is the gradual lessening abilty of some CPUs (or mbrds?) to overclock at their 'as new' level.
I've been running this XPM @ 2.5GHz for a little over 2yrs now ,it used to run fine at that speed @ 1.66v ,but about a month ago I started to have problems with my rig crashing.
A P95 test showed that the CPU was no longer stable ,PC would lock after a few hours or so.It used to pass a 24hr P95 test ,I've upped the vcore to 1.68v & it seems to be ok now ,but something's fading!
Also ,many years ago I had a K6-2 350 ,for about 2mths it was fine at 420MHz ,then 1 day it just refused to load windows (BSOD) ,backed it off to 400MHz & it was fine.
Good to see you'll be crunching more & your rigs running cooler
Wiz
Wow you had a massive drop with new AS5!:Q
[edit]woah ,just realised that's the 1st long discussion I've had in DC for ages!
