Here's the situation:
I have an old Pentium D 820 in a system where the case came with the fan shroud. However, whoever put the thing together added an aftermarket cpu cooler (CM of some sort) that has a downward blowing fan. There's obviously a fan on the side panel at hte top of the shroud. So, here's the question:
Since the fan is pulling are thru the heatsink and not upward towards the side panel, what's the best setup for the side panel fan/fan shroud? The original builder left the side panel fan as an intake fan blowing down the shroud towards the cpu hsf. Is this even a good idea? My understanding on those was they were originally intended to vent the cpu heat out and not for pulling cool air in, right?
So, should I leave the shroud off and just use the side fan as a case intake and leave more room for air to circulate inside? Or would there be any advantage to leaving it the original config so it's pulling in fresh air to go down and thru the cpu hsf? The only other option I see is turning the fans around and using the shroud, hsf, and case fan as exhaust.
I'm torn. Does anyone have any suggestions?
It's a mid tower case, but there's a decent amount of room. I've got a 120 mm intake on the front panel, 2 x 40mm exhaust on the rear + the psu fan blowing that way on an Antec psu. I had pretty much come to the conclusion that it would be best to just ditch the shroud and get that fan blowing in and let the cpu hsf do it's own work.
Any help greatly appreciated.
