Greetings everyone:
Does anyone happen to know how to remove the Pentium 4c heatspreader and then reattaching it? When I had to clean the last Arctic Silver 3 application, I used alcohol, soap and water to try to clean the hole on the P4c-3.2Ghz heatspreader and then tried to flush the inside of the hole with water using a syringe that the water flowed out the bottom of the heatspreader. I wonder if this removed any of the thermal interface material between the top of the CPU core and the heatspreader.
