TrECeNTeRs
Heres My Quest....
I'm trying to help out a friend. Any help with this situation is apreciated. ((( Keep in Mind A Tight Budget )))A couple years ago he purchased this computer from GATEWAY on the order he said it was a 1.8Ghz P4. w/ RAMBUS RDRAM ... If im not mistaken...
Well when he booted it up it shows 1.9 in the properties. I have no idea if gateway Over-clocked it up 100mhz or if they just put the 1.9 chip in it.
What I do know is that it is the "423" the OLD version of the P4 before they made the socket more compact.
So Probably the best thing to do sence I couldnt get to any FSB or Multiplyer options in the BIOS that GATEWAY has setup would be buy a new board.
I'm not sure of the FSB mhz of the rambus or if it can even be overclocked.
I'm also not sure if the CPU can be overclocked especially on this board.
RAM "rambus rdram 800 or 400 not sure"
I figure it would be cheaper to stick with RDRAM I hear it is fast, but I have also heard stories of it not being very compatable and the company that makes it was trying to be somewhat a monoply. This is just what I have heard true or false I don't know. I'm not sure it it is 400Mhz or 800Mhz RDRAM. I will have to look next time I'm there. Eather way its 1GB.
Video Card "Probably 2x"
It is an AGP board but im sure its not an 8x, We got him a 5200 Ultra to put in it. So its a decent machine for Gameing. I'm thinking he should wait for theese newer cards to dop prices of other cards and get a new video later when prices drop. I usually try to keep a $150. Limit on a Card Upgrade.
Hard Drive
The 7200 rpm harddrive shouldn't need replaced. I figure once A game is loaded onto the 1gb ram and the video ram the harddrive wont have to do much work. So harddrive is fine.
Power Supply
The power supply is probably 300watts my guess but eather way I use genaric PS's 550watt dual fans for like around what $18. And that supports my AMD machine with 8 fans xp2600@2.45 2x196 fsb @ 41c deg. and goes no higher in mhz cause of the nforce2 "thanks to blue on here for tellin me that" So sorry for bein off subject but Power Supply should be alright.
Ending Question
So basically IMO unless theres someway to OC this machine by unlocking "GATEWAYS" bios stuff and maybe adding a Volcano. and a few Case Fans. Ram Sinks ect... He is probably looking at trying to find a "Newer Motherboardand" and "New 478 type P4" combo that hopefully that supports RDRAM. So he dont have to spend alot on getting another gig of ram but also be able to purchase new faster ram in the future when needed.
Any suggestions? Questions? or even Opinions about GATEWAY Lol? Please feel free to post.
It will all be apreciated!
Hard Drive
Power Supply
Ending Question
