Config:
- Pentium 4 Motherboard: ASUS P4S533
- Intel: Pentium 4-1.8 GHz (Socket 478, Retail)
- case: Chieftec Server tower DX-01BLD,SPX-2
- 2*256MB PC2700 DDR crutial
PS: more info about the case can be found at http://www.newegg.com/app/viewproduct.asp?description=11-125-116
Got a few problems for putting everything together.
For one, I had problems putting all these LED cords on the motherboard. I assume the black is the ground as usual. If that's true, I am good so far.
The second problem came with a power cord named "H.D.D led". Doesn't take a brain to know this is the HD power for the led indicator. However the only two places left on the motherboard seem to be one that is for the MLED and the SMI. I have no idea what they are both. Which one should I connect to?
The third problem arise when I was supposed to setup the switches of DSW1. It is supposed to be setup based on how fast is my CPU and ram. I am not sure what to put. I am not even trying to overclock the CPU, but I am not even sure what config to use.
The fourth problem is the USB card. Why do I have a USB card in the first place? In my old motherboard, I didn't even have a card like for USB. Yet, both motherboards have USB connections. So why does the ASUS P4S533 need a USB card?
The final problem is a jumper problem: I would like to remove that beep (if there is a beep, when you start the computer). If that's possible, how can I do that?
Thanks in advance for answering.
