- Jun 27, 2005
- 53
- 0
- 0
hey
My pentium 4 640 ideals at around 46-50 and at full load its gets to around the 60 degree mark so i am looking to lower that temp a little bit.
I was lookign at the zalman 7700 however non of the aftermarket heatsinks seem to be able to fit on a asus p5ld2 deluxe anyone know which one to get? anyone have this cpu/motherboard which heatsink do you use?
Also the reason i need better cooling is beacuse i have overclocked it to 3.8ghz and it is prime 95 stable but at that overclock it runs at 67-68 under full load, and around 53-55 idle any help would be great.
also my ambient temp is 30 at idle and around 34 at load. also has anyone gotten a pci slot fan does that help lower temps.
Thanks
Thanks
