Is anyone using the Pennzoil or Quaker State Multi-Vehicle ATF in their transmission? If so, please state the year/make/model of your car, as well as the shift quality.
I'm interested in using this fluid in a Honda Z-1 application, as this fluid is a composed of a Group III basestock opposed to the Honda ATF Z-1's Grp I or II basestock, which should allow the Multi-Vehicle ATF to have better oxidation resistance and a longer service life. Jiffy Lube and many independent shops use the Pennzoil or Quaker State Multi-Vehicle ATF, so if you've had a transmission flush done by Jiffy Lube recently, they would've used the Multi-Vehicle ATF.
The reason why I considering to deviate from the factory, OEM Honda ATF Z-1 is because of the many issues I've had with the fluid turning brown or black, within 15 or 20,000 miles in the newer, post-recall 5-speed Honda/Acura automatic transmissions. (2004+) IMO, the Honda fluid is not up to par and is depleted very rapidly and I'm hoping that the Multi-Vehicle fluid will bring a longer service life.
